Depends on where you sail.
Don't believe the SPOT device is connected to international monitoring as the EPIRB is and coverage is not world wide. Took one on the sail to Hawaii and stopped working a couple hundred miles north of the Islands just as its coverage map said it would. If you are going to use the SPOT, be sure you will be sailing where it will work.
