do you guys back east draw the line and quit sailing. I know the boat gets hauled out at some point or date but if the weather goes south prior to then, when do you say enough is enough? I draw the line at about 60 degrees. Maybe 59 if it's a really good day. I used to be a bit tougher but being as my boat is fitted with a temperature compensated autopilot that turns south at 58 degrees I don't get the chance anymore.
