bring the plastic cover back to original clarity. I have some "Autohelm" instruments that were getting pretty sad that I used it on with great results. I can't help you with it's not lighting up other then to say that I took mine apart and cleaned up the buttons and mine started to work again. I think the guts of the Raymarine and Autohelm are pretty much the same so that might help you as well.
