Ever since I read years ago ( in some Mag) of a off-shore production boat needing assistance after they survived a storm because the o-rings in the diesel and water fill failing and allowing salt water incursion, I check them, port seals, and water log seals carefully at the beginning of the season, intermittently thereafter. I use a silicone based grease on them.
