Oh and while researching that, I found a How to make site that had this to say
Important: French Press brewing is used to make fresh coffee to consume immediately! It is not good to leave the coffee in the press for any length of time.
Tailor the size of the press or the amount you make to what can be consumed in 10 minutes or so. Do not try to keep the coffee warm. Don't let the coffee sit long in the press; even in the plunged position as it continues to extract. If you need hot coffee for a longer period and want to use the French Press, decant the coffee into a thermos after brewing.
That's just a snip- here's the site-
http://whatscookingamerica.net/Beverage/FrenchPress.htm
