Return to Index
Read Responses
It's pretty strong and lasts a lomg time.
In Response To:
They also hate it because it's tough to work with
How long does the new polyester last when put up against Gortex? IMHO it's worth the extra money.
Anyone have any thoughts on sail covers?
Send your needs, specs and wants to
Wasn't aware of that issue with Sunbrella.
Maybe just have it lined.
QuickCover
first I have ever heard of the Sunbrella thing
Interesting … our Sunbrella Main Cover is probably 12 years old, maybe more ...
I don't cover, if I am sailing the next day
Same here. How much UV is left in the late afternoon
If I'm traveling, and anchored out, I usually leave them uncovered. Otherwise the covers are on
I have a what is basically a Stack Pack but
2 years, that sounds crazy.
And how many Sunbrella Bimini's get replaced that often?? Mine sure hasn't.
What can I say?
I realize you're quoting North. All good info, thanks.
Sail Covers
Dorsey has always made ours....
Lucky guy! Does she use Gortex thread?
I agree it's worth it
I believe our Bimini and dodger ...
Hell, if I can figure out thread tension using Tenara, I should think a professional could... (grin)
Sounds like a PITA to do all that
Tenara is also making a coated version now that makes sewing with it even easier
If the sail cover is white and you're in the South...
I am embarrassed to admit..
Well, maybe. I've had a white Sunbrella bimini and a maroon one
Sent an e-mail to Glen Raven on this issue.
