I have a similar problem every time I change coolent. I
solved the problem by filling the engine from the bottom. I removed the block drain plug and installed a valve with a hose connected to it
Now I remove the end cap on the hose, fit a funnel into the hose(which will reach the top of the engine) and add coolent until I see it in the expansion tank. I top off the tank and end up with no air.
