You could try pulling a vacuum...
any kind of positive displacement pump that has an inlet you could attach a hose to. Even your dinghy pump if is has a connection to pump the air out of the dink. An oil change pump would work too. Neither would be calibrated and may not be able to pull the full indication but you should be able to see some suction.
