Don't make this complicated
This is dead nuts simple. Put the threaded end into your mouth. Suck. Have some one watch the needle to see if it moves. You should be able to pull a few inches of mercury.
Now if you want to calibrated it or make sure it goes to 30" under a full vacuum, that is another story. But I would only do the foregoing.
David
