The new marina here is pictured on the cover of Anne Hammick's cruising guide if you happen to have that. The marina supervisor, Jose, has to be the nicest guy running a marina anywhere. You can also anchor out, in sand along the 10 meter line, if the swell isn't too bad. We did that while waiting for a slip to open up.
Where are you eventually headed? We're leaving early August for the UK, and will probably winter somewhere in SE England within shouting distance if London.
