Pad eye mounting
In Response To: Thanks guys ()
Make sure you mount it so the loop of the eye runs perpendicular to the boom (more or less in line with pull). The momentary snatch loads might run pretty high and otherwise if you mount it longitudinally the loop might be bent to the side.
