Yes. I'm plugged into the dock and the charger is in float mode.
Both banks (each one is 700AH) are showing a charge current of 0.1A. The only thing I don't like about the Clipper monitors is the charge/discharge display. You have to look close to see the tiny "CHARGE" displayed between the volts and amps. When discharging, this changes to "DISCHARGE". I would prefer something that stands out more, such as a large minus sign in front of the amperage display.
