I highly suggest you give it a try. It's flatter water and it has two pretty good reefs to snorkel on. It's also a 40 minute walk over the hill to town and the market and a fifty paso cab ride back with your provisions right to your dinghy. It's a great spot to provision, Much better then where you are and way better then Bara. The water is clean and clear, out of the swell and has a good sand bottom.
