I gave up on doing that. I just spend the
In Response To: Masking tape ()
time and re-tape. I use the Home Depot blue which is pretty inexpensive compared to stuff WM sells. It seems that every time I left any tape on for more then one coat, even though I cut the edge with a blade, I would lift some varnish somewhere when pulling what ever I had used off. I've changed most of the small teak pieces over to SS or Starboard and now just have the lager sections like the caps, combing, bowsprit and Pilot House doors left. We're, thank goodness, past the build up coats again so it's a single coat now. Taping on the outside is the simple job. Taping the inside is the bitch. We just did all the teak the head and all the teak battens on the overhead in the main cabin. I'm not sure what else she has in store for me but I saw her checking out the galley the other day.
