Return to Index
Read Responses
YOu can make your own ethanol free gas.mix with some water shake it up and wait
In Response To:
Many places selling non-ethenol gas
it separates and you can siphon off the gas or check this out..
http://pure-gas.org/index.jsp
http://tinyurl.com/mce5eda
Another outboard fuel problem
just look for ethanol free gas
our club buys its own gas from the local supplier
I was told … by law all gasoline sold in Massachusetts has ethanol in it ...
Gotcha … thanks Larry ! Cheers, John
John - before you buy AV Gas
Wow, scary … thanks Larry. Cheers, John
Yes, you will remove the ethanol and you will have some 60 octane fuel...
AV gas is usually a low lead product. I used it a bit here and.....
Awesome Larry … THANKS. Chatham Airport has it ! You made my day. Cheers, John
we've found the pure-gas website to be pretty accurate
