Thanks! Do you use the internal or external ground terminals...
In Response To: I use.. ()
or the ones that seem to be supplied in the Garmin kit? The Raymarine cables have foil covered with braid but no drain wire. It seems like it would be hard to push the braid up inside an internal grounding shield.
Those EZ terminations look pretty easy!
