I used a thin metal shim,between one angle bracket on the engine. I needed to shift the engine horizontally on one mount to get the shaft line true. It was pretty easy to loosen, slide the engine away from the bracket and slide in a shim- tighten bracket. I think I used those open ended shims like the ones they used to use, to align front ends on vehicles. Perfect fit.
