... pressure wash, many hours of 80g sanding, fairing, Solvent 202 wash & wipe, 6 coats of 2000e (probably equivalent of 4 coats as the stuff was put on with a foam roller, then 5 coats of Micron CSC (ablative) also rolled on with foam roller, so maybe the equivalent of 3 coats had I used a nap roller cover. Done the last couple weeks on Cape Cod so temperatures 60 or so. Thanks, cheers, John
