Return to Index
Read Responses
It is, after all, the beauty of wood. You can take off or add on when pressed.
In Response To:
Don't scare me. I could write a book of mistakes. Measuration causes most,...
Cockpit news: I have a carcass.
Tom, I can see the problem in that first pic.......
LOL... jeeze and to hear this from someone willing to tackle such a project...
If it looks good, it is good.
And I learned a long time ago to try to always use the same tape all through the job
Tom, what is the metal ring in the floor of the old cockpit forward of the pedestal?
That is a manhole, D'Arcy. They were pretty common to Alden boats
Good idea, I wish I had that on my boat.
Re: That is a manhole, D'Arcy. They were pretty common to Alden boats
Hi Jayz. What did you do? I'm looking for gasket ideas.
Re: Hi Jayz. What did you do? I'm looking for gasket ideas.
You might...
Thermal expansion.
Both the cover and the round frame are solid bronze.
JnbRe: The small grove might be for a o ring. I have two
Good idea!
