The 2003 Around Islesboro Race featured a hole in the wind just as you approached the narrowest part of Bracketts Channel where you need to squeeze between a private marker showing where the depth drops to 2 feet, and a private dock. a whole bunch of boats came steaming up under spinnaker only to drift at a most dangerous spot. If you look close, you can make out the private mark (dark yellow), just off the stern of a Ranger 26, middle right.
