from having boat hauled out and moved north to PNW. Most of this is just putting stuff in to place for use at sea...
Have to finish inspection of all the rig work... make sure the new lighting works right, and check that all cotter pins are bent. (I found two that were not)
I have water tank issues that need to be taken care of... before any long adventures.
Put on a quick coat of varnish about a week ago... while we had warm weather. Will probably put on another coat tomorrow... weather is going to be fantastic. Dry and up to 80. Whoo Hoo.
This weekend is supposed to rain... so probably hank on the main after the rain. Or just get the sails to the sailmaker and order new ones. (which I should do... these sails are very very old)
