Return to Index
Read Responses
Re: Dyneema single braid, 1/4"
In Response To:
I like the non metal termination idea they use for the synthetic the right fitting and I am set.
I want to isolate my binnacle from galvanic or electrolysis
Wouldn't it be better to provide a conductive path to the zinc?
Re: I want to isolate my binnacle from galvanic or electrolysis / Tom, put out a call on
Thanks Steve
Re: Thanks Steve / Tom, try http://shop.saltydoggs.com/Corrosion-Test-Kit_c3.htm
Re: Thanks Steve / Tom, try and
Tom, I did mention that I was old didn't I? Put your meter on the 2 VDC and
Thanks for the heads up Steve, I'll post when I get results.
