Return to Index
Read Responses
Will do, Steve.
In Response To:
Make sure you let us know what you or your electrical expert figure-out ;^))))
Heart Interface Monitor
Half volt drop
Re: Half volt drop
A diode produces a half volt drop
Re: A diode produces a half volt drop
Hmmmm
Re: Hmmmm
Re: Hmmmm
Re: Hmmmm / I'm thinking that battery isolators usually drop the voltage a half volt so if
Isolator or Equalizer does have a drop -- BUT...
Where did you measure the voltage with your voltmeter?
I used to have a Heart Interface with a Link 2000, but it's been a while...
Another sources is our "Maine Sail" -- but I think he's in Casco Bay -- or farther DownWest from you
Thanks all
Will do, Steve.
