Return to Index
Read Responses
Gene, did you see the competitors in the R2AK?
In Response To:
You can always guess which barges are going to Alasaka...
http://tracker.r2ak.com/
Photo Day June 22nd
A recent barge going to Alasaka...
Shakedown: "A limited sea excursion for the purpose of testing all the working equipment of a ship
Re: Shakedown: "A limited sea excursion for the purpose of testing all the working equipment of a sh
Not a bad idea, but beware those 'spring' versions. They can break fingers!!
Re: Not a bad idea, but beware those 'spring' versions. They can break fingers!!
Some people just try to push them down as if they were air cylinders.
Good to know
Check these out
Ooh, I like the idea of gas struts. My heavy large hatch could enjoy those.
Re: Gene, did you see the competitors in the R2AK?
If you think that's crazy, my friend Karl is paddling his SUP...
Ouch...
Staying on the barge theme
also on the barge theme. On the Gulf ICW you get to see this about 20 times a day, between
