I'm liking this latest bowl of spaghetti from Weather Underground.
Maybe can leave the main on the boom tomorrow after all!
Still have to finish the oil change begun Monday. Had to be an other side to the easy genoa folding. The hose on the two-decade old Topsider vacuum failed. It broke off at the connection to the tank. When I cut off the end and refitted it, it split. When I went ashore to try heating it a bit, the enema-clamp had crushed the tubing which broke, messing up the shed. (Good hadn't brought into the kitchen!) Stopped at the local marine dealer and bought a Marpac for only $25 more than Defender. But it worked better than the Topsider ever did! Then couldn't find where I'd put the spin-on filters so that project remains incomplete. Tomorrow.
