Interesting problem...
The type 2 linear drive uses a recirculating ball bearing screw system. I have only taken the shaft out of one once, many years ago.
Read this: https://en.wikipedia.org/wiki/Ball_screw Before you proceed.
It sounds like you may have some debris in the screw, maybe a cracked ball bearing.
