Return to Index
Read Responses
I'm with RichH on this one. You will probably need to descale the coolant side.
In Response To:
Anyone know at what temp (more or less) freshwater from the heat exchanger should be (i.e., after it's been cooled in
I used Permatex #18 Radiator Cleaner on recommendation from a Volvo dealer. Worked great.
Paul L
Overheating
The outlet temp on a Hx is 'engine dependent' ......
Correction ... thats "CAN" be dumped overboard when (nm)
Flow and temp... (link)
Note on IR temperature "guns"
Re: Note on IR temperature "guns"
