Return to Index
Read Responses
Re: Note on IR temperature "guns"
In Response To:
Just saw that Wed-Fri the Craftsman/Extech most basic model is on sale for $20.
Jerry
Anyone know at what temp (more or less) freshwater from the heat exchanger should be (i.e., after it's been cooled in
Overheating
The outlet temp on a Hx is 'engine dependent' ......
Correction ... thats "CAN" be dumped overboard when (nm)
I'm with RichH on this one. You will probably need to descale the coolant side.
Flow and temp... (link)
