onto its keel bolts after drilling ten 1 1/4" holes through 3" solid glass. What a relief to see all the holes line up with the bolts.
So, instead of a photo, imagine the stress on our faces as the TraveLift driver gingeraly maneuvered the giant machine and boat over the 7000 keel, carefully lined things up, and successfully let the boat down. It helped that we drilled the holes correctly too
