I checked the net and can't find much info.
For example, the boxes shown as being installed, how many KwH do they produce?
Since the core works at 1000 celcius, is there a way to re-use the heat output?
What's involved in regular maintenance? That stuff about reversing the mode doesn't work in a boat: emptying your batteries to clean the filters of dust.
Looks interesting, as so many things that then just vanish into vaporware.
