Return to Index
Read Responses
Only one problem Dave-- you still can't pump and Electra Scan overboard in LIS because it's a NDZ
In Response To:
if you're in salt water, it seems to me that an Electra Scan is the answer.
composting heads
thoughts
I have a friend who likes them, but
Several things to consider...
I used to have one on board Bremer Speck
Larry, I don't believe that all of LIS is a no discharge zone...
That's my understanding as well.
You are right Dave, but there is no place in CT (within reasonable commute to your job) where you can use it.
Right, I saw Peggie's post down below.
Here's the pic...
LIS is not an NDZ, but...
Lectrasan output may be "clean" in terms of bacteria count...
NDZ
A friend has one and likes it but
