Return to Index
Read Responses
I'd be amazed if the feature will connect without a compatible rate setting compass
In Response To:
Garmin over Raymarine!
The input depends on the proper NEMA or bus connection "sentences".
HD radar
another question with this
MARPA?
Probably only when stopped. Your system should be able to use GPS heading info when underway..
On our Furuno units (past and current), you need a rate of turn sensing compass -- not just a bearing heading?
You Need the Rate Sensing Compass for MARPA
Raymarine uses a high speed compass instead
Tried our Raymarine MARPA without a high speed compass.
What number is that Crag?
radar chartplotter
I don't that unit. You might check reviews out.
Yes indeed
The what I got
I think you made the right decision.
