I checked that, and called Xantrex and asked ...
them about it, specifically telling them my situation. they suggested leaving this setting at the default, which I think is 2%. I have that setting for both the Start and the House, so I am thinking this is not it, but maybe it is. I also have the Peukert setting for both banks as the default as well (1.25), so not sure that is it either.
I do what chesley does, go into the set up procedure every now and then when I'm fairly certain things are fully charged, according to the Start #'s on the L20, and reset the House, then I am fine for a couple weeks. If I plug into SP, the resetting automatically by the unit itself usually takes me a couple hours, not days.
thanks, cheers, John
