Well, all of this is incredibly informative. The bottom line is that I can get the Flooded batteries at less than half the cost of AGMs. I don't have a fancy charging, equalizing etc. system on the boat now, so I will go with the cheaper batteries which should last several years. When it is time to upgrade the system, then it may be worthwhile to invest in batteries that can take advantage of the system.
