Return to Index
Read Responses
The cable could cause stiffness
In Response To:
Edson pedestal control question
"Morse" cables are cheap, and you can buy 3rd party cables because they are generic. Start there.
Cable......
Diconnect the cable from transmission linkage...then
the issue is with the throttle lever, not gearshift
Edson recommends a cable clamp
Edson control question
FWIW, I used stainless cable clamps of the appropriate size...
hmmm, but if this is already stiff
Disconnect the cable
Duh......that's a great idea!
Thanks nat, the picture really helped. Details.
