This is the chart table on the starboard side of my 1936 woodie. The counter top is white maple. I intentionally left a small gap around the edge of the counter top so I can caulk it to prevent spills from leaking into the cabinet below. There will be trim over the caulk, which will go in tomorrow. The final door for the bin at the bottom of the cabinet will be installed after the hardware to keep it closed arrives - hopefully tomorrow. The pic is after the first coat of varnish - 6-8 more to go.
