If you're going with a soft bottom you might want to consider adding transom wheels that can be lowered so you don't need to drag the Hypalon fabric if you pull it up on a beach. Since you're already shopping Defender, you should get in touch with Stephan Lance there. He's very knowledgeable about all the makes/models and will steer you right.
