I got very lucky with a similar failure
In Response To: Wasn't GOBI but yesterday... ()
A week ago I pulled into the dock for haulout at the end of the season, shut the engine down then shut off the main battery disconnect switch. When I shut off the switch it went crack and then the knob just spun freely. If there was a good time for that failure, that would have to be it. Fortunately the chandlery is only a few blocks away and they had stock on an almost identical replacement.
