Return to Index
Read Responses
The newer Unlimited Data plans of Verizon w/ a matching device would be less expensive
In Response To:
Droid or IPhone
IF you have some other reason for having a "Blackberry" type device.
wifi antenna recommendations
Are you looking for just an antenna or a system?
just an antenna with a booster if such exists
Droid or IPhone
yes, I have a droid with the Verizon
I have use this guy advice with good results
i use the alfa 500mw - total cost about $50
I have decided ...
John is correct....
Wave wifi
Alfa on ebay cost $ 40 some odd bucks and works great!
Engenius EUB 9603H is another good one.
Alfa vs Engenius
One big advantage of the Alfa is
Down Side of the Alfa
i got the alpha 500mw...1 usb connection
blye - does the 1000mw unit work off of two usb ports like the 500mw unit?
