Return to Index
Read Responses
The float switch
In Response To:
Then it's the switch -- unless you've wired the pump wrong.
odd Bilge pump operation
Your 3 position switch would seem to be "off"?
pump wiring
The float switch
By the way.
float switch?
There's only one float switch to use....
looks like they clamp to a rule pump...
Float Switch
