Return to Index
Read Responses
Yup, always ...
In Response To:
If it works...I'd take it apart and lube it with SuperLub (non petroleum, teflon) semi- or annually.
How often should an older Raritan PHII Head be rebuilt ...
I do mine when the turds begin to start going the wrong way
Yup, always ...
Actually Raritan recommends rebuilding only about every 5 years ..
Wow, thanks Peggy. I was hoping you'd chime in ...
Is a squirt really enough?
It is if it's enough of a squirt...
Which begs the question...
