Don't be stingy with it...turn the pump upside down and squeeze the tube hard enough to send a HEALTHY squirt of it into the pump...with the piston in the up position if you like that better.
And btw, the same teflon grease is the best stuff for lubing seacocks, y-valves and anything else that stays wet.
