Return to Index
Read Responses
Good idea Larry.
In Response To:
One more thing -- use rubber pipe end caps
I flushed the system out pretty well, but still..
Sanitation hose advice
Any system that has that many unions needs to be re-designed for more simplicity.
listen to peggie. mine used to be 22 feet long.
Been there done that John
Good idea Larry.
Yeah -- and if you wrap some duct tape...
KO is good
Get yourself one of these ...
conclusions
John did you get the exact type (with the ratchet)?
Same type, different brand.
