Return to Index
Read Responses
The problem is that thlithium metal batteries in Epirbs apparently contain more than 2g of lithium...
In Response To:
Ask your air carrier in advance
The web sites I linked to above note that this is a rule from the FAA.
DOT Link
epirb
Send it in checked luggage.
Put the documentation with it, so the "mysterious object" will be understood
I'd carry it on...w/ the technical informaion.
You might unscrew the antenna and take it off just in case
It will depend on the battery type...
A bit more checking shows that some newer EPIRBS have non-hazmat batteies...
Issue is probably the concern with what it might look like or what it might really be concealing
That's why they have sniffers and dogs
The issue is that lithiummetal batteries are a fire hazard
Lithium Metal or Lithium Ion Batteries?
Where I found information EPIRB batteries were lithium metal...
Of course since TSA does the screening...
But if ...
The you are screwed
The war's over, the terrorists have won.
Seems that way eh?
well if we stopped sending them
Isn't this how we beat the Russians?
We have to make that declaration BEFORE we send billions in high tech weaponry to Saudi Arabia.
