The water lines are reenforced PVC for the non-pressurized and the gray plastic like you find in mobile homes and RV's for the pressurized lines. They are all very efficiently zip tied together everywhere and attached every couple of feet with zip tie adhesive backed squares to the locker sides. I would sure like to find the culprit leak instead.
