I have one of those
In Response To: Just a WAG ()
It is in the supply line to the "T" which supplies both the pressurized and non pressurized lines. I had it apart for some reason which escapes me right now. It is located in the same locker as the pump. That would explain the air bubbles for sure, but not the leak into the bilge. I will take a closer look at it this weekend. Thanks!
