You should also consider...
In Response To: Acids and other things ()
If it is such a small engine, how hard is it to drop the pan? Sludge will have built up in the pan and no amount of oil changing will get rid of it.
It sounds like you may have a lot of hours on that engine. Worn rings mean you will never get the oil clean. Short of a rebuild, just changing the oil more often will help.
