Plus, I can't imagine that you could replace an W/C Junior with one that you'd want unless you had a load of room.
If you want reliablity and availablity of parts, I'd get a Raritan PHII with two rebuild kits and an extra pump assembly, plus a large tube of SuperLube (to lubricate it regularly). You should be able to go a LONG time before you need anything else.
