Calisto, This adapter, for example
http://cache-www.belkin.com/support/dl/f5u109.pdf
Is a Belkin model. Check to see if your adapter has i) it's own drivers properly installed and updated; and ii) there are drivers for categories of SOME devices that (hopefully) will make the system work.
Killing the "phantom" pointing device probably will work; however, there should be a more permanent solution
The serial input (if you had one on your machine) clearly would be addressable -- but that has been become a lagacy device ;^)
