Yes I have blocks mounted to webbing loops sewn into the sails
Fore and aft. It makes the single line reefing work smoothly as it should. Would never have SLR again without ball-bearing blocks throughout the path.
You can see them in this image on the leech (only the first reef block on the luff shows, because the luff block for second reef is mounted starboard). They never scratch the mast.
